Comand illumination
damnearperfect
Hi all
I've just had comand retro fitted and it works ok - but the buttons on the set don't light up at all nor does the map direction indicator screen show up in the centre of the speedo.
The car is an E270 W211
Any ideas
Thanks :confused:
damnearperfect said:
Hi all
Any ideas
Thanks :confused:
Sounds like the job isnt finished.
Hi all
Any ideas
Thanks :confused:
sounds like it just needs coding to the cluster for satnav.
if its showing up "no navi" on the cluster then it means it isnt fitted properly (no canbus wires to comand from cluster), but if it doesnt show no-navi and no nav info is selectable from the cluster via the steering wheel buttons then it means its not coded by a MB dealer.
get yourself to a dealer and get them to switch on the command for the cluster.
do the lights on the command work if u manually set to "night mode"?
