Terryk
Thank you @Alfie for your prompt reply.It's not the headunit.
It is the navigation drive or the antenna. The drive has all the navigation componentry in it. How long did you leave the system to find the antenna and collect satellites? It can take 15 minutes.
Those drives are £3,000 from Mercedes!!!!! Fortunately if the drive does need changing then there are much cheaper routes ;-)
Apologies, I was meant to write the navi drive at the boot and not the actual HU in the dash.
Maybe the navi drive, for a reason that I cannot understand, doesn't power the Fakra plug. I tried to measure the volts but was reading 0v and not the expected 3.5v-5v but was using a cheap voltometer too..
