Combi Antenna GSM/UMTS/GPS/AM/FM
M
misterb
Guest
Hi
Is there any one out there who can help me find a cheapish antenna?
To cover GSM (quad range) UMTS, GPS and AM/FM
I am having so little luck find these all in one antenna the only websites
I have found are
http://www.tdc.co.uk/index.htm
www.panorama.co.uk
and they a very expensive, well to me!!
Look forward to any help thanks :bannana: :bannana:
This one is tri band, doesn't do AM/FM but covers the mobile networks and GPS.
Had one on our A Class, bought from:
http://www.dashmount.co.uk/antenna.htm
The one I'm talking about is Product code 704. Was about £60 at the time, similar aerials from MB where over £110 at the time. There was a Hirschamn one too but I think that was about £140!
What vehicle is it going in?, Do you really need this aerial to cover AM/FM too?. Can't you use the existing radio aerial for that?
Hope this helps.
Hope this helps.
If MB uses one antenna for each task then I doubt very much that anyone will do such a product.
Exactly my point. The only combined aerial I knew of was the ML and A Class, GPS & GSM combined aerials.
Just fitted one to our W163 ML...
Even then it has up to 3 cables coming out of it meaning that it is just a package with 3 antennas.
