I just did a compression test in my continuing efforts to fix the slow starting on my 300TE-24, here's what I got;
1/ 110 PSI
2/ 100
3/ 105
4/ 115
5/ 130
6/ 130
These seem very low to me, I'm not totally convinced of the accuracy of the tester I used but I hoped it would give me a rough idea.
The car takes quite a few cranks before it will start, but once started it will run OK, it doesn't cut out or stall and it seems to have plenty of power, although I haven't driven a known good one for comparison.
Other issues I've noticed is disappearing coolant (though no visible leaks) and a bit of oil that has come through the breather hose into the air filter box. There doesn't seem to be any oil in the coolant or coolant in the engine oil.
1/ 110 PSI
2/ 100
3/ 105
4/ 115
5/ 130
6/ 130
