Hi All
So I have a Mercedes E250 CDI Blue efficiency 2010 Reg Saloon (Diesel 2.1L)
Currently the coolant level is dropping down every 2 days after I top it up to full and the level decreases by half a inch in 2 days.
I can see clear signs of fresh coolant color and water around the fuel filter housing area.
However, from the service history i can see that the car was fixed by previous owner for the fuel filter housing due to the same coolant leakage together with some seals.
Now I do not know what to do next. Could it be fuel filter housing again or any other thing around it? will a water pressure test help identify the leak?
I need your advise how should I go about it together with some good reasonable garage (specialist) near Slough who can identify the problem and fix it in reasonable price. I dont mind driving 20miles around to go to a good garage that can fix it without high charges.
Appreciate your kind advice.
Kay
Kay
