Gazwould
Preeeeeeeeeemium diesel...very successful marketing con .
It isn't 99 ron if that's what you mean. I was disappointed when they moved from 99 ron to 97 ron just before my local opened! For this reason I use Shell V power instead, although it's very expensive atm.Is Costco premium diesel actually premium, as their premium petrol certainly isn’t premium
If we are discussing Diesel fuel then the RON number doesn't apply. That is only used to define the ability of a petroleum fuel to avoid pre ignition detonation.It isn't 99 ron if that's what you mean. I was disappointed when they moved from 99 ron to 97 ron just before my local opened! For this reason I use Shell V power instead, although it's very expensive atm.
The premium diesel has more additives, how it compares in the real world, I don't know Ash
How does that work then?All fuel comes out the same pipe at the refinery the only marginal change is in some of the additives which are added to the refined fuel before its dispensed and those are very very minor despite all the marketing they spend many thousands on, the main driver for all the so called premium etc adverts is to get you in the shop because thats where they make massive margins.
All the fuel has to be to a minimum standard which is always above the standard set by the car makers, what happens in the tanks at the forecourt however is another matter it has been known for a few hundred litres of the wrong fuel to get into the wrong tank!
It was in response to Ash's comment about their premium petrol not being premiumIf we are discussing Diesel fuel then the RON number doesn't apply. That is only used to define the ability of a petroleum fuel to avoid pre ignition detonation.
If we want to look at the "quality" of Diesel then we need to know the Cetane rating.
This is from a 4 year old post on Costco UKs Facebook page. At that time it said it's premium diesel has a minimum 51 cetane rating.If we are discussing Diesel fuel then the RON number doesn't apply. That is only used to define the ability of a petroleum fuel to avoid pre ignition detonation.
I seem to recall that Costco add the additives at the forecourt - if that's correct, maybe they forgot to put them in.
Back in 2002 when I had an E46 M3 (sensational car) super unleaded wasn’t as easily available as it is these days. On the odd occasion I put normal 95 into it and the engine would pink on light throttle applications. Stick Shell Optimax back in 98 Ron I believe and it was back on song. Today, the new M5 parked in the driveway says 95 Ron is fine to use in the fuel cap - strange.Story doing the rounds for years used to be that the only difference between branded and supermarket fuel was that the delivery driver mixed in different additives.
I suspect that won't work with RON99 vs RON95 fuel - but then I also suspect that if you stick RON95 fuel into the RON99 pumps the majority of purchasers wouldn't notice as their car engine management systems don't make any special adaptation to RON99 fuel. And as for those who do have engines that benefit from RON99 fuel I would suspect that that they don't drive the engine hard enough often enough to get the benefit that often (But arguably there will be those who would notice the benefit on those occasions when they actively exploit it).
From WikiWhat's Cetane
