crankshaft position sensor on cl320 convertible
mvmv
clk320
Hi All,
Engine has randomly cut out twice now and reading errors tell me its the crank position sensor (code 052). in order to solve the problem that I've had twice now, it was a simple case of disconnecting and reconnecting the battery.
So, is it a simple case of changing the sensor or is it something else?
help?
thanks.
why does it start working against when disconnect and reconnect the battery?
It starts working again when the engine cools sufficiently.
When the engine warms up at some stage your engine will cut out again.
Connecting and reconnecting the battery is immaterial.
disconnecting and reconnecting the battery did work though....
not forever, but a couple of times.
