DAB windscreen aerial
AndrewOl
Romsey
E350 A207
I have a GL with NTG2.0 which sounds ok but the FM reception is pants. Looking at options to improve radio so was thinking about DAB. Stick on internal systems are cheap but has anyone had a good result with them?
Also looking at fitting an external aerial for FM and DAB by drilling a hole above front courtesy light unit. Bit more involved but can't see why it would not work. My company car has DAB and I never listen to FM so if internal screen aerials work than this would be the way to go.
Has anyone tried the internal DAB aerial route with success?
Cheers
Andy
Cheers
Andy
Hi fitted a stick on internal on my clk really good reception and no fade well pleased with it
DAB reception quality is all about the aerial and it's installation. T
Here are good antenna and bad one :-) If you have a radio that has the phantom feed to power the antenna via the coax then I suggest using an Alpine KAE-242DA-R or one of the latest Funke antenna.
R
