Daimler warning to car owners of fire risk
"It added in the letter that the parts needed to fix the problem were not immediately available so a recall was not possible at the moment, but would be launched as soon as the components became available.
"In the meantime the affected vehicle should be driven in a particularly prudent manner and usage reduced to the bare minimum," the letter said."
Seriously....????
Some addition information from the Netherlands:
Refers to OM654 and OM656 engines. Odd if a coolant leak can cause fire?
No letter in my country so far. Wife's 213 seems to be on the list, build date summer 2020. She's already driving only when necessary and I'd say carefully.
I have not renewed my TIPS subscription, would anyone with access tell more about the issue? Perhaps owners could check some symptoms if instructions were released.
Years Jan 2017 to Oct 2021
Anyone knows if the W205 C350e is impacted by this issue? (UK reg 66).
The C350e has a petrol engine, so if the issue is indeed limited to OM654 and OM656 (both are Diesel engines), then you car is not affected.
Some more technical details here:
"The pumps installed can be controlled in terms of their delivery rate. With a so-called demand control, their drive power can be reduced, which in turn should contribute to lowering consumption.
Another advantage of the internally interrupted coolant flow (the thermostat only depends on the radiator) is that the machine heats up more quickly, with additional advantages in terms of raw exhaust quality. The engine electronics use electrically operated control valves for this. Due to the defect, coolant can leak at the interface to the vacuum."
And also here:
"Germany’s Bild newspaper first reported that hundreds of thousands of Mercedes cars built between January 2017 and October 2021 may have a leaking coolant pump. In rare cases, this could lead to extremely high temperatures, which increases drastically the risk of fire."
Thanks, I posted before reading article in full.
Headlines I came across did not specify this only impacts Diesel engines and I am planning a trip to Barcelona for Easter break hence my jumpy question...
Appreciate the reply. 👍
Not if whatever's no longer being cooled gets too hot ;)
Luckily no mention of the OM654 we have in our V class, ( 447) 👍
I wonder how much coolant will the cooling system need to lose before things get too hot under the bonnet? And does the issue only affect those owners who initially ignore the 'coolant low' warning message, and then go on to ignore the 'engine overheating' warning message.....? I would expect the dash would look like a Christmas tree well before any fire starts...
cut
Some additional information there. I'm just lost with explanation, coolant can leak to the vacuum? Which vacuum, I guess not outer space.
I don't think it can be the engine getting hot from low coolant. The simple advice (that would not even need to be given) is to top up if the light comes on.
I have not read how the pump control actually works. I assume it is still mechanically driven but is there some sort of a "clutch" like radiator fans used to have before those changed to electric? This part would not be in contact with coolant then. Would it make the serpentine belt burn?
The photo is showing an electric connector, so assuming that this is indeed a photo of the offending pump, then the issue could be that the leak is causing some sort of an electric short-circuit perhaps.
I am guessing that Daimler just ordered 800,000 pumps from their pump supplier.... who supplied the faulty pumps in the first place, and will probably be footing much of the repairs bill (them ot their insurer).
If its anything like the OM651 COOLANT pump its vacuum actuated but electrically switched [vacuum on and off] meaning it will be connected to the engine vacuum system which may in turn affect other components-its not clear from the picture
That’s exactly what I thought, bound to be a few warning signs before the planets aligned and a fire broke out surely 🤷🏽‍♂️
