I've done this job before (taken an old loom and rewired it) and most of the plugs are factory heat-sealed to themselves. They have to be opened with a Dremel with a wood blade then re-sealed using Sikoflex sealant. This includes the three important coil pack plugs. Perversley the CP plugs from an R129 320 are dismantleable but cost over £30 each from Merc
Also the short length of the harness that goes from the 'neck' in the cambox to the coils is a rubber moulding with the three trigger wires and the large +pos feed heat-sealed therein. If anybodys interested I have some pics of what I did. It certainly isn't a straightforward undo-solder-redo job. If you have cruise and the donor car doesn't the loom is different.
