Dash Cam
stef ptycia
2008 E320 CDI Sport Tip Auto
Anyone hard wired a mini 0805 dash cam. If so how and where.
Mounted ours behind the rear view mirror and wired from Overhead Console.
In our case it's a Blackvue unit but applies to all cameras
sinewave said:
Mounted ours behind the rear view mirror and wired from Overhead Console. In our case it's a Blackvue unit but applies to all cameras
Thanks Sinewave.
Is your feed permanent or live on ignition.
I fitted an extra cigar lighter socket in the boot under the parcel shelf, (£4 amazon). That way I didn't need to cut the plug of the camera and it can be used on my next car. I just used an "add a fuse" so no wires cut.
I'm also wanting to hard wire mine. It's a pain having the wire hanging down.
Just run it along the headlining/windscreen, down the A pillar trim and then under the passenger dash to the power socket, no need for wires dangling.
