royaltiger
- Sep 10, 2010
- W204 C220CDI Sport
Hi I recently purchased C220 CDI sport (06) and would like to add daytime running lights (DRL's) to them, the lights I purchase basically had two wires a positive and negative and it seems sellers advertise you to just wire them up to the headlights, after a bit of further reading there is more to this than meets the eye, so in other words your DRL's are fine in the day but as soon as you turn on the headlights they must switch off. So I bought a DRL module that says it will do this, all you have to do is wire into a negative, which I have done and wire into an ignition live which I have done, on a third wire it says to wire this into the low beam + which I thought I had done but the DRL's are still staying on when headlights are switched on, so this is the bit I am confused on is have I wired it right.I connected to the back of the drivers side headlight cluster or o/s headlight which has a 5 pin connection also marked 1 - 5. 1 is a black wire with green stripe, 2 is brown, 3 is white, 4 is yellow and 5 is grey with a red stripe. I have wired into the grey red stripe wire pin 5. I used a circuit tester to check a live feed and this was the only pin that lit up tester on side and headlights so came to the conclusion this was the low beam positive connection. Am I right or is there more to this or have I done something completely wrong, obviously something is not right as DRL's do not switch off when headlights are turned on. Should I have wired into back of switch on dashboard ? all help greatly appreciated
