- Jan 10, 2019
- Location
- Cardiff / London
- 2x E350 CDI Sport W212s, Golf Mk4 V5.
Video spinning just the hub for what it's worth. Appears to spin true:
You're right as I can still feel some play when the disc is on. Perhaps I could try the space saver wheel? Probably a bit big...You need the disc clamped to the hub. The wheel bolts are too long to do that without fouling the strut if wound in sufficiently to clamp with out the wheel being mounted.
Either, use shorter bolts (awkward) or spacers on the existing ones. Improvise - sockets, bits of metal tube, etc.
Yes, I think I'll try with the space saver as the caliper is still there hanging off to the side and the full size wheel will probably foul it.Could you bolt the wheel to the hub without the brake disc, you'll definitely see any run off then?
Where you have the disc mounted on two bolts - is that as far in as they will go? Looking at your vid in post # 41, there doesn't seem to be anything for them to foul.You're right as I can still feel some play when the disc is on. Perhaps I could try the space saver wheel? Probably a bit big...
I'd like to figure out a way to test this, for curiosity's sake if nothing else...
Spacers required. Even timber will do. Just enough clamping is all that is needed.Yes, that's as far as they would go. I tried with 5 too and they just 'stop'
