Diamondbrite on used (waxed) car.
Rory
Cheshire, UK
C270CDi Estate (late 2004 facelift model) - Bought 2005, Sold 2022.
It's a year old car, that's been waxed several times. As the Diamondbrite stuff is supposed to bond to the paintwork, I assume that if the car's been waxed, it'll bond to the wax?
Therefore, do I need to T-Cut (or similar) that wax off first?
Not sure about what it bonds too, but instead of T-cut, if its the wax you need to remove, I would recommend a clay bar...
A good polish with a good quality polish using clay bar on any stubborn blemishes should do the trick. But you do need to get all wax off or the DB can't bond ;)
You must get rid of the old wax,ideally get the bodywork steam cleaned.
hope this is ok for some members without the CAPITALS.
What about a panel wipe or similar - should remove all traces of wax etc?
Will
to be honest the diamondbrite base coat removes the wax from the paintwork
Thanks - that sounds easier than steam cleaning etc.
Thats what I thought too.
