spock500
As you guys know the head has been off to be reconditioned.
One thing that always bothered me was the 'fizz' when each cylinder was under compression, if you looked down the inlet duct and squirted oil around the valve seal you could see it bubble under pressure.
I pointed this out to the Head Centre who recond the head and back it went for vacuum testin g which came up 100%, I even sent the cams and valve lifters back so it could be tested as is.
I was told that the equipment they use doesnt require lapping in, its so accurate that the seat is cut then it beds in by itself.
