Hi all,
Not sure if anyone can answer the following definitively....
My wife currently drives a 2007 B Class and wants to change cars.
She would like to stick to a B Class and maybe get a 2012 or 2013 used. Problem is she was told by a friend that the seats on the newer model are much lower than the old Pre-2012 shape. And even the specs state the the W246 is about 6cm shorter than the W245.
But my research on the actual difference in seat height is unclear. Can anyone definitely confirm the actual difference in seat height - relative to the road - between the old and new?
As you may have guessed - the raised seating position is important to her.
I did take her to check out a couple of actual B-Class but the first we tried was a Sport trim - which I believe is slightly lowered. The 2nd was a 2015 model - which again I understand had lower seats (than 2012/2013 versions) as part of a facelift?
She did try a Renault Captur and Ford Ecosport - like the raised seating - but not impressed by the interior quality.
Thanks in advance for any answers....
