Distronic 2 upgrade
greatw
I know its a long shot but is it possible to upgrade a Distronic system to Distronic2?
It turns out that the control unit on my Distronic is broken so if I am going to replace it, is the upgrade possible and is it worth it as the function is basically the same.
Thanks in advance.
Alex
Hello greatw I do not think that you will find that it is possible to upgrade 2.
I take it that you would like the STOP and HOLD functions since this was normally used With SBC it would mean a new pump as the software is not the same
Thanks Malcolm. I thought that would be the case.
The unit was faulty when I bought the car and I found out today that the garage removed the control unit to prevent any further errors as it was faulty. I figured it could be repaired but they say not :-(
Any idea where I could source one from and how much it is likely to cost?
Thanks again
Alex
Thanks again
Alex
steve@mbenznl.com keeps them in stock.
Oops I missed out the important bit! No, its a W220.
Miro, Thanks I'll drop him an email and see how scary this is going to be :-)
SG CL500, so what I need to do is find another car with the unit installed and torch it ;-)
Seriously though I'll make some enquiries and let you all know how I go on. After all that is what the forum is for.
Thanks all
Alex
