As above,
If the tyres are all /40/R19, but have difference widths, then the two rear tyres would be taller (i.e. have larger diameter) than the front ones.
You want to have wider tyres at the rear, but keep the same tyre height (diameter), and this is achieved by having lower profiles on the (rear) wider tyres.
I'd always wondered why the rear tyres had a lower profile (i.e 35 not 40) than the fronts.
There's a mismatch in tyre+wheel rolling diameter there- think your rears should be
285 35 R19
SEE
Car Bibles : The Wheel and Tyre Bible
As above
Said that, while in essence the wider/lower tyres will require wider/taller wheels, if the wrong tyres were fitted on the original MB wheels, i.e. the car still has the original factory-fitted alloys, then you are in luck and you can keep the wheels, just replace the tyres with the correct ones.
The fronts dimension is right.The rears are a tiny bit taller profile than OEM.
In fact the difference is only 4mm,which aint enough to cause problems.
The rear profile hight with the OEM tyres (275/40/19) is 110mm and the tyre that you have now (285/40) is 114mm.
Your harsh ride is not because of the tyre dimensions.
What is the cars weight and what is your current pressure on the tyres?
It could be tyre pressure as you say. But it can also be that you need to change some bushes,balls and joints on your suspension.That makes a big difference to ride quality.
About a suggestion above...You don't need to make the rears 285/35. This is the Brabus setting and its only 100mm tall. You now have 114 mm profile on the rear ,which is better for comfort.
If you want to be 100% correct on OEM settings,i would suggest you go to 275/40 (110mm) instead of 285/35(100mm).This would keep almost the same hight of the tyre with reduced footprint,which would be better for ride quality and noise.
It is all about the tyres being the same height. The rears in the OP's case have the wrong profile and therefore they are too tall when compared to the fronts. If you have 255/40 on the front then you should have 285/35 on the back...because then they are almost exactly the same diameter (being only 4mm difference on the radius).
I think you'll find the rears are 24mm ( an inch in old money) taller than the fronts. This is far too big a difference. I would be surprised if the cruise control worked...that's hardly a tiny difference as you state.
The difference between 255/40 and 275/40 is 8mm in the radius, not 4mm as you state.
So, the suggestion for 285/35 was indeed correct.
I do not know whether having the wrong tyre size is the cause of the OP's issue.
But I do know that wider tyres have lower profiles in order to keep the height (diameter) as similar as possible. It is as simple as that.
If you do not accept this statement, then we will have to agree to disagree.
... It's about helping the OP with his specific problem..... All you need is follow Mercedes's guides and use your logic with OP's specific parameters.
