- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
One of the occupational hazards of the job that I do (Inspection Engineer) is that I tend to look at the parts that I fit.
The photos show a drop-link for the E300TD.
The weld at one end is garbage.
If you look closely, you will see that the toe of the weld is not fused to the stem of the link for about 20 per cent of the circumference.
Will it fail in service ?
Probably not.
However, the lack of weld fusion presents a clear stress-raiser on a load bearing suspension part. This could initiate a crack which could propagate and cause a failure of the part.
The link I bought for the other side clearly says "Germany" on it and is a much better job.
One of the features of my work at the moment is sorting out rubbish like this, that is made in the cheap-labour corners of the world, in factories where the technology of what they are doing seems to be little-understood.
The lesson ...
Look closely at your safety-critical parts before you fit them.
Cheers
Johnsco
Probably not.
The lesson ...
Cheers
Johnsco
