Door Seals
yes the outside ones are
A1247201124
you dont want the back ones do you? from memory those are really £
What do you mean by 'back ones'? I assumed the seal was one piece, from door mirror back to base of rear side window.
Ok think we are getting confused.. there is a seal that runs at the bottom of the window on the door (quoted above).. stops water going down the side of the door
then there is a seal that runs all the way around the aperture which is number 42 below... if its these then they are £90ish from the dealer
Does anyone know how long changing all these seals would take?
Yes, it's number 42 I need. although what is 38, and what is 35?
I assumed the seal was 'external'. It's the bit that you can see when stood outside the car, and the rubber is perishing a little.
38 is a metal rail that the seal sits on and 35 is alike a long rubber intermediate strip so the metal plate does not sit directly on the metal body...
