Right quick question regarding my duovalve (also known as heater valve). When engine is hot (85 deg C) and temperature selector dial is turned fully Blue until it clicks, there is a loud and unmistakable tick tick tick from the 2 duovalve cylinders. I can feel the ticking vibrations greatest when I touch the pipes into the duovalve (the cylinders itself is too hot to touch). When I turn the dials towards White or just take it slightly out of fully Blue, the ticking slows down (longer intervals) and eventually stops. Someone mentioned its the solenoids ticking - is this normal? Is it struggling to completely shut the valve to prevent hot coolant from entering the cabin heater? Does this mean its on the way OUT?
Some background: my radiator has been completely replaced with a new unit (core and expansion/header tank). AC wasn't working but now fixed (1 relay and 1 fuse so no major component replaced). Blows cold but not like a Jap car though so I'm starting to get concerned it is being hampered by hot coolant getting to the cabin heaters and affecting my AC coldness.
