Are pagid on the same level as mb original discs? They look the same - only asking as I'm due a change soon.
In my opinion these bits should of been same colour as wheels, look forward to seeing the calipers though!
I was informed by my local Indy that pagid are a supplier to MB.
Good choice of colour (but i would say that) lol, Textar Are Oem friction wise, not sure on the Disc's.
TMD friction Distribute Pagid, Mintex and Textar and also Eurocar parts cheaper pad brand Eicher. (wasn't always the case)
Pagid discs are fine, but I'd recommend oem pads. Plenty of instances of brake squeal with pagid pads. To avoid excessive dust I'd recommend EBC Red stuff pads.
how much is it?
Where are you getting ebc pads from? Looked at the ebc shop and there £80 just for fronts! Got front and rear pagit discs and pads and sensors and fitting kit for £202.
Yep, forgot to mention they aren't cheap EBC shop is same place I looked.
Depends how much excessive brake dust annoys you I guess.
I'm a little OCD here, but are the drilled holes in the same pattern as original?
Anything reducing brake dust is good, but I think the red stuff may be a little bit of an overkill with the need for them to warm up properly. Heard a lot of good stuff about Ferodo & Tarox
Does anyone know why TMD use so many brands? I've never noticed much variation in price across them so would be interested to know if there was any difference in compounds.
As for Pagid, their discs are fine but their pads squeal like a piggie.
Perfect, guessing my choice of discs is sorted then - unless MB ones are priced the same.
