E200 W124 tapping noise when cold :-(
marcintosh
Sheffield
E200 W124
Just heard something a bit worrying. Loud'ish tapping noise right after starting from cold. It disappeared when I accelerated. When hot, the engine ran smoothly as always. The car has done 120K miles.
Cam chain/tensioner?
Possible a tappet on the way out ?, not filling up with oil properly after startup, once the engine is hot the oil thins a bit and finds it's way in ....
If you have a good indy and are on a budget, he should be able to isolate the tappet and change that one (i did this , cost me £60 as i am poor) , otherwise change them all ...
Sounds like someone banging a bit of scaffolding with a screwdriver ...
Somone else more mechanically minded will know for definate, as i have all the technical know-how of a tin of corned beef ...
Almost definitely a hydraulic tappet, and nothing to worry too much about. Sometimes a change of oil grade helps. There is also an additive obtainable for such a fault. Mine had this fault until I changed to a fully synth. oil (5W/40) about 10 months ago and has been fine since.
That's exactly the sound it makes. It is due for oil service soon so will see if it changes anything.
