Zubair
Need help, i have w212 (e220) 2015 face lift, recently i asked my mechanic to install a reverse camera (which i bought), however that didnt work out well as camera never worked plus i lost the hazard panel (incl. Car hearting /eco buttons and passenger airbags sign), dashboard watch not working and also one reverse light is dead.
Mechanic said he has checked the fuses, which are ok and i need to replace the whole Comand system. He said faulty camera or bad Comand system may have resulted this issue. Backlight he said he never connected so its just separate spark taking down the light. Usually boot connected tail light is quite robust so not sure why this is the case here.
On ebay i notice only hazard panel is available for sale.
Replacing the whole Comand system is expensive but i am not sure if purchasing hazard panel will solve the problem. And also not sure about the connection of dashboard Watch too.
any advice or experience about this hazard panel and how i can check if the panel is faulty, plus how i can unscrew or split that hazard panel from Comand system? Any recommended electrician in or near london preferably.
thanks
thanks
