Wondering if anyone has any ideas.
I have a 2003 w211 E270 CDI. Had a slight judder at 70mph around the 2000rpm. Guess what, just had the radiator replaced and the torque convertor due to the well known faulty Valeo radiator problem. I was unforunatley to have glycol in ATF but only had a slight judder.
I had a local auto transmission garage to do the job as I dont have a ramp. They fitted a re-manufactured convertor and new Rad.
They had the car for a week and handed it back over but said the clutch plates were soft and they were not sure how long they would last.
As soon as I took the car back there was a new nasty harsh vibration coming from below the centre console around the gearbox
Took the car back and they changed the torque convertor again (their expense). Also had the clutch plates changed while it was out again. However the vibration was still there. They took it apart again, stripped the box and changed one of the gears because the coating had slightly come off it. Cant see how that would cause any problems as the gear was not damaged.
Vibration still there and now they seem lost. They are now trying to swap parts over from a donor vehicle to try and locate the problem.
Does anyone have any ideas what the vibration could be. Never had it before the garage started the repair.
It is a very heavy drone / vibration at low speeds on acceleration. Gets worse after about 5 mins starting from cold and feels like the car is slighting struggerling to get going. On motorway cruising all I get is a very minor vibration now and again.
