328matt
Hello all, i am a new mb owner w210 e320cdi estate avantgarde. I have done some searches and am still a little confused.....I have been told by a recommended independant that my pre-cat is becoming blocked. When the car was on the ramp he showed me that it was blowing exhaust gas over the engine from a clamp by the pre cat.He said it was blocked and from the forum i can see that it is not uncommon...A lot of people
on here stay away from non mb parts, so is the answer to empty the cat of its innards, buy what is i imagine a very costly part???I also read that there is a probe after the pre cat so if i remove the innards will that cause the engine management to misehave? Incidentally i have just had an a service,replaced the glow plugs and gearbox oil. I have been told that the rear shocks are leaking-expensive i am told!some bushes up at the front are gone-another £400, v belt needs changing, and there is a slight weep from the diff-all seals changed-another £250. I have had the car a month after getting it for a song, and want it right!Seems i am having a baptism of fire!-is it true i could run without any cats?? Thanks for the help.......Matt
