10k …….are you serious ? What parts (or was it mainly Labour charges ?)
Only paid labour to diagnose an EGR leak, install brake flexis and flush, tyre changes, and several alignments. Everything else done myself.
Bought with fresh "major service" but previous owner was kinda scammed too.
Done 44k miles in 2 years. Sitting shy of 162000 now.
In order, what I remember more or less goes as:
Air filters. (dealer)
Complete PCV assembly. (dealer)
All charge seals. (dealer)
Engine and tranny mounts. (dealer)
Full Brembo brake service. (eBay)
Brake flexi lines. (dealer)
Transmission service. (dealer)
Oil change every ~6000 miles. (dealer)
Front FEBI suspension bushings and lower ball joints. (eBay)
Injector bolts and seals. (dealer)
Fuel filter. (dealer)
Rear shocks. (dealer)
High end oil cooler job with new cooler, flap motor, new left manifold, new bolts, all new gaskets obviously, etc. (dealer)
Upgrade swirl flap linkage. (X8R)
Injectors reconditioned locally; none of them worked. Waste of money.
3x new injectors. (dealer)
3x new injectors. (Bosch supplier)
Tail light from reversing in dark garage. (dealer)
Batwing/MAF assembly. (dealer)
O2 sensor. (Bosch supplier)
Intercooler. (eBay)
Boost pipes. (dealer)
Another couple sets of air filters. (dealer)
Belt tensioner. (dealer)
Chinese turbo actuator. (Amazon)
Broken AC compressor clutch: bypass with shorter belt. (Amazon)
Spare set of tyres from the parts car.
Rear subframe mounts and other couple bushings. (dealer)
Lemforder rear spring arm to hub joints. (eBay)
All drop links. (dealer)
Used accelerator pedal. (eBay)
Crank and Cam sensors. (dealer)
Atmospheric, boost and backpressure sensors. (dealer)
Odd seal and flange from charge circuit. (dealer)
Upper engine temp sensors. (dealer)
Air spring that had not been replaced yet. (dealer)
Jack pads. (dealer)
Two sets of front struts from breakers. (eBay)
ALL of the tailgate weather sealing components. (dealer)
Fuel lines that had not been replaced in the oil cooler job. (dealer)
Michelin PS5 tyres. (Local garage)
Reconditioned turbo actuator. (eBay)
Alternator regulator. (dealer)
Some minor service items.
Other parts bought already but pending replacement.
and not counting the many thousands in tools and spare parts for R&D between this and my "project" car (2008 E280 CDI Sport Estate)
