E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
If you had both cars next to each other then yes. You would have to transplant the wiring loom and control units from the 210 into the 202. It would be a 202 with 210 running gear.
Would it just not be better if an e320 was bought? Apart from the rust issue which w202s also suffer from, its larger that the 202 and there are plenty of nice 210's around. Its just a matter of looking!
The best solution is to buy a Merc model with a bigger engine. Prices for big engined models in the UK will be falling with increasing fuel and VED costs.
I've recently seen C43s sub 4k too, so rather than go through the hassle of an engine transplant, I'd buy a car which is 'straight out of the box' so to speak :bannana:
