SavMan
I have trawled through 6 pages of airmatic posts on this form but can't seem to find an answer to my current issue. I have a 2003 Estate that I bought a month ago and today realised I had a puncture and the car was also not level, however after inflating the tyre back to correct pressure I realised there was still a slight difference in ride height. After driving home I measured this evening with engine off/engine on and in different settings/ride heights. In all settings the o/s rear is anything between 5mm (comfort, sport 1 and 2) 10mm (increased ride height) lower than the nearside rear. There does not seem to be any excess noise and both sides take the same time to rise and settle.
Should the car be level? Or am I being to particular and the difference is within normal tolerance? If it should be level is there a simple way to calibrate?
