Egr , boost, dpf , help!
Yes please spill the company name with incompetent software .
Probably Avon Tuning...
I mean, how can you tell if the software isnt actually working or if there is an issue elsewhere?
Can’t name and shame them just yet but they are a Chippenham based company.
I can understand people getting sick of DPF faults but I’d be pretty annoyed if I bought a car and the previous owner had gutted the DPF. Same with AdBlue and EGR deletes. Getting these things reinstated is a nightmare.
Premises with rolling road or a recommended mechanic across the way to do the hardware bit then a mobile remapper ?
Not a bad approach, BUT I would hazard a guess that the majority of owners who gut the DPF after having DPF issues, do so because replacing the PDF and/or sensors etc is prohibitively expensive for them. When taken in this context, any follow-up action that require considerable expense is probably a non-starter.....
Having adblue on your car is the real nightmare, deleting it will save many hours of heartache and thousands of pounds in your wallet.
Can anyone recommend a place to remove DPF and egr in wiltshire area?
You said in your first post that the DPF has been removed.
Has it been removed?
He wants good software as it's been done , a competent remapper needs to work from his original file rather than the bodged remapped file so he needs the original software file put back on .
The remapped software will usually carry a satisfaction refund and put back to original software .
Out of curiosity, what was the original issue with the DPF? Was it not possible to just have the old DPF cleaned etc?
Dpf cleaning is a money making enterprise as it rarely involves getting to the root cause.
Get root cause sorted then clean if necessary , trouble is it's a bolt on flawed idea with far too many prerequisites .
The worry is doing it all again and then having the same issues 😵
So buy a petrol car or accept a diesel with a DPF and EGR.
As asked, why do it in the first place? I Why not have the initial fault fixed?
It's not as simple as that , it's called the dpf Merry-go-round and I've seen people close to breakdown !
So it's not surprising people turn to the dark side .
Amen
