recycled
As a trained mechanic, I have always believed that if a car has a fault, be it something worn, broken, perished, cracked, seized, overheated, malfunctioned or failed in some other way, then that fault MUST be repaired properly. That means either replacing a component or repairing/ reconditioning it. Adding some liquid in the hope that you'll be saving a fortune is sheer fantasy, and best left to the sub 20 year olds who subscribe to the Halfords car culture (if you get my meaning).
Any comments would be appreciated
bubble124![]()
I am not sub 20 and the wynss reducer worked for me. reduced co from 0.7 to 0.3.
But if your cat is totally past it, i guess it would not help.
As for repairing the car properly are you going to get a merc CAT which would cost over a grand? as your car may not be worth that?
No need to get all worked up, many have worked for me so if it does not work for you, maybe your car is past saving but generalising is not going to help.
if you have a flat tyre, you do not need to get a new one as some liquid puncture sealants work so " nothing but nothing works " is too much of a sweeping statement.
advice is to get an after market CAT if that is your problem and maybe check your A/F mixtures. have you got a MAF?
