So we start our engine, slam into gear and go
don't give a monkeys what Mercedes say
I still didn't get your point on the VI issue. I chose Mobil 1 because it has the highest VI than any other oil that I can get hold of. Also its the cheapest oil I can get! 0W40 costs me 8,75 euros per litre - around 5.8 pounds. How much for it in Britain?
I can wait. Thanks.C240yaz: Thanks for the feedback. I didn't forget you but the guy that I know at the MB dealer is on holiday and is back on thursday. Hope you can wait till then.
Hey pal,DanSLK: don't stop any turbocharged engine without letting the turbine/compressor wheel reduce speed to minimum. Oil starvation would result because the bearings are lubed by engine oil and it gets there by pump pressure. Also if there's a lot of heat in the housing, this will fry the little oil that stayed there. To be on the safe side, I try and reach my destination with little or no load in the engine so that the turbo is in a relaxed state of mind and ready to sleep.
I think the original poster's car has a volumetric compressor that is run by a belt so when engine stops, its stops too. No need to do anything special, I think.
Thats what happens when you let your 6 month old kid play with the mouse, triple tap on the post reply button.You must have a lot of extra fingers Danslk..![]()
One thing to add, every mechanic who served a recognised apprenticeship at a dealership or OEM and attended college over a 4 year period, gets taught this and sits examinations on this to obtain his qualifications, and may I add, several months study night and day, so nothing here is really new to a trained technician.Well...
I know the discussion has been wrapped up, but out of curiousity,
eurico and Dieselman what do you think about this guy?
http://www.carbibles.com/engineoil_bible.html
Mercedes disagree with you:
