JonnyShez
So the honeymoon period with the C220, purchased less than two weeks ago, was brought to an abrupt end on Tuesday night. Driving home from town after work and the dreaded engine management light flashes up on the dash! Gutted, I've had previous with this issue on my previous car and it ended up costing me a new Nox sensor (£350+).
Anyways, yesterday morning I took the car to Mastertech Assist (Droylsden, Greater Manchester), my local independent Mercedes specialist who ran the diagnostics and found a 'stored' fault relating to an O2 sensor upstream of the catalytic converter. Was told that this meant the fault was not affecting the car and that once the code was cleared it should stay off...the plot thickens...driving home from work again, the bleeding light flashes up again :fail
The car is under warranty so rang the dealer today where I purchased the car from to explain the situation. Surprisingly there was very little resistance over the phone and I'm currently awaiting a call back to say when he (or his 'Mercedes guy' as he put it) will be available to have the sensor replaced.
Anyone else had this issue before? Will a simple sensor replacement be the end of the problem or will there be more woe
Will find out soon enough!
