Engine Management Light
gazza9911
Durham, uk
Mercedes CLK 320 (2001)
Hi Folks,
I've just started my CLK 320 (208), it turned over for a few seconds before firing up. Once started the engine management light was on. I switched the engine off and restarted with no delay - EM light still on - drives OK.
Looking on other posts, I couldn't find the same thing but from what info I could find was -- the computer detected a fault with starting which corrected itself -- Am I correct in understanding that the EM light will turn off on it's own or will I need to take it to be turned off.
Cheers Gazza9911
You need to get it plugged into a Star to see what the cause of the light is.
Hi All,
Again folk answering differant questions that have been asked, the question asked was: Am I correct in understanding that the EM light will turn off on it's own or will I need to take it to be turned off.
:doh: But the answer to my question is: Yes the EM light WILL reset itself (as it has). I know that I need to get it plugged into Star to find out what caused the light to come on.
Cheers
G
Not all engine warning lights do. It very much depends on the fault hence why I said it needs to be plugged in.
