Iv'e a W203 c200k (1.8).
Car driving fine until on the motorway today when it started to have
engine vibrations and suffered a loss of power. The engine management light came on also. It continued to drive but there wasnt the proper power and clearly was not right.
I pulled into a lay by and put the car into neutral but the engine was vibrating badly. I called a Merc garage and boy told me to stop engine, get out, lock and then get back into car. I did so and started it and all was smooth again albeit with the engine management light still on.
I drove the car to the Merc garage and on opening the oil cap you could see the problem. The oil was like a gunge. Boy tells me the wrong oil had been put in and and this is what happens with this engine. He plugged in into the computer and this confirmed what he said.
He says even a total flush and new oil will only be a temporary solution beacuse it will be impossible to remove all the contamination. He believes that the engine is now on the way out and eventually the timing chain will go.
Has anyone had a similar experience ? I'm just seeking other opinions to see if in fact this is likely to happen or has happened to anyone else. If so how long can the engine be expected to last ?
Any help or advice would be very much appreciated, thanks.
