Engine problem
tom_coe
W203 C220 CDI
Hi this is my first post on this site. I drive a 2006 w203 c220 cdi that recently has been running really bad. I noticed it go into limp mode a few weeks back, after turning the car off and on again it would be fine for a while then I'd be limited revs again, then one night driving home the engine management light came on in my dials, the next day i had a diagnostics check done and it returned the MAF as being the cause of the problem, I have fitted a new MAF but the car seems to be running worse than before, it's using a lot of diesel, will be in limp mode constantly and I have noticed a lot of diesel smoke on the rare occasion that I have kick down available. If anyone has any suggestions on what the problem could be it would be much appreciated its beginning to become an expensive issue.
Tom
Find a specialist close to you... (not sure where you are...) get them to read the codes and establish the underlying cause.. there are so many things it could be on a modern turbo diesel....
Thanks for the reply, im in Kent, I've read a lot about the egr valve and intake manifolds but like you said I'm best off finding a specialist
right. faulty maf causing carbon depositing ,egr fault.replacing maf is not enough.need that cleaning.takes few hours.instructions on this site
Thanks for the reply, after this is cleaned will it this remove the light??
no,for that obd scanner or stardiag
