DITTRICH
Dear All
After bringing back my C230K from the 'dead' - flat battery - started first time with new battery, I had a problem.
I let the car idle for about 20mins to see if it was running okay - it was. Then a funny thing happened. It cut out and refused to start again.
Called AA. After much tooing and froing, it seemed - no fuel pressure - traced to fuel relay in boot - not activating on turning ignition key. relay worked fine, but insufficient voltage being fed to relay to activate it when starting. The AA guy bridged the relay and the car started. However, now there seemed to be some grey smoke coming out the back of the exhaust where none before, particularly if the engine was revved. Didn't want to do anymore so turned off engine and removed the bridged relay.
I know it needs to be taken to the garage to have the codes read, but would it be safe to drive a short distance, or do I need to trailer it to an indpendent the nearest of which would seem to be in brighton - car currently close to Tunbrdge wells. ANyone know of an independent closer?
Rgds
Les
Rgds
Les
