corned
Hi all.
Here's another winter issue with the 211. I have had similar less pronounced symptoms earlier in the year, but now the cold weather has arrived the symptoms appear to be getting worse.
From cold, the engine revs wander around, particularly on a very light throttle setting and at the lower end of the rev range. Occasionally, it gives the appearance of a clutch which is slipping and the drive is hesitant and jerky too. The throttle input is steady, but the revs hunt up and down by a couple of hundred rpm. As the engine warms up, the symptoms gradually disappear. When fully warmed up, it behaves exactly as it should - smooth as you like.
I6 E320CDI, last of the I6s, 5-G 'box. ATF+filter change less than 20k ago.
Do you diagnose this as:
a.) They all do that, Sir!;
b.) MAS on its way out/needs a clean;
c.) Sounds like there's not enough ATF in your torque converter;
d.) Gearbox is sha**ed;
e.) None of the above.
Advice and opinions, as always, very much appreciated.
