cellarmerc
Hi, I had the EPC visit workshop come warning light come on after my car died on the motorway.I pulled over and restarted the engine .It started but this happened about 1000km ago as well and after diagnostic test although appearing on the computor result as a fault that happened the garage didn't really find a problem.I changed the plastic fuel ipes thinking this was linked to a air in fuel problem (which was known to be causing starting problems). Can anyone say what they think is wrong.
I should also mention a clutch that is slow to return to the correct position on starting the car and often springs up after a slight delay.It seems to rectify itself .
thks
Tony
thks
Tony
