wobbly
- Aug 3, 2004
- Location
- Middlesex
- 2018 GLC 220d AMG line Premium + 1989 500SL Now sold, replaced with 2007 Aston Martin DB9
In late January, in a attempt to cure the ABS problem I was having on the SL, I decided to change the Brake light switch.
Being as I was busy at the time, rather than go to the dealers to get the switch, I ordered one via Euro car parts to be delivered, not something I would normally do.
I had changed the Brake light switch in my ML, this took no time, so I thought the SL would be the same, how wrong I was it took hours, lying on my back in the footwell legs in the air, stuggling to undo and the tighten locknuts in a confined space, only able to get one hand in the space, and two spanners needed top undo the nuts. But I got it done, although it didnt help with the ABS light situation.
Since then the car has covered about 300 miles.
I was out for a drive this morning, pulled up at a set of traffic lights, when a young couple in a ML pulled up by my side, and said I had no brake lights. I was only a few of miles from home, so I thought the best bet was to get home and try and sort the problem.
At home checked the bulbs, and the fuse no problems found, I thought it couldnt be the brake switch, but it was the only other thing I could think of.
I luckily kept the old switch, so before removing the one in the car, I connected the old switch and manually operated the switch, the brake lights worked fine.
So another hour and a half stuggling upside down in the footwell, the brake lights now work.
The moral of the story, always buy genuine parts, as in the longrun it saves time and money.
