Hi & welcome.
That consumption does sound a bit excessive, although it is still relatively low mileage and will probably loosen up yet.
I have a 2007 range brochure and can look up the official figures if you can't find them in your handbook. Need to know:
Particulate filter or not?
Manual or auto gearbox?
High or standard roof?
Standard or optional rear axle ratio?
The official figures are based on the published kerb weight (empty van). Obviously what you get in real life will depend on how much load you are carrying.
No Particle Filter,
Manual drive, standart roof, medium chasis, standart gear ratio.
2020 kg, with leather seats and fridge.Michelin Agilis tyres, vehicle allready on shuttle service, so no heavy loads loaded except luggages, loads does not exceed 300-400 kg's.with driver and passengers. But figures I gave, not loaded figures except fridge, seats and driver.
Offical consumption figures are 11.3 lt/100 km Urban, 7 lt/100 Highway, 8 lt Combined.
By the way I just discovered, both front tyres has wear off from outside, seems like wrong toe or camber setting?Rear tyres looks brand new with smooth surfaces but fronts wear off from out sides with rough surfaces , Would this settings has effect on consumption?
Dieselman, veichle did few smoked start, my friends noticed, i didnt see, I was on driver seat, they told me veichle started with a blast like sound from exhaust with smoke?? But it happen just few times not more than four.
