Exterior right hand mirror for 98(ish) SL, E, C
richard
Berkshire, UK
MY04 SL55
Hi
I have a right hand (drivers door) exterior mirror from my UK 1998 SL. The triangular piece unscrews and then its the same as a C or E class mirror of that age, infact it has 210 part numbers on it.
Its heated with memory, dimming function, is green/black and in excellent condition.
Also, I have the dimming mirror glass which is around £150 to buy from MB. You need a dimming inside mirror to make the outside dimming work, and there is 2 wires that need to run from the inside mirror to the outside.
(I updated to newer mirrors) - Im in Lightwater, Surrey
I want £50 for the mirror itself,£50 for the glass, or £75 for both.
welcome to the forums! pls try and post pics if u can for other members!
Are you sure it is the same??
<img src="http://www.mbclub.co.uk/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (V12 @ July 04 2002,19:01)</td></tr><tr><td id="QUOTE">Are you sure it is the same??
<img src="http://www.mbclub.co.uk/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'></td></tr></table><span id='postcolor'>
Once you unscrew the mirror triangle (labeled 129 ... .. ..), then it has an E class part number on everything, including a summary of what the mirror is
Ill try and take a photo
R
Yep, i checked today and they are indeed identical! <img src="http://www.mbclub.co.uk/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
