I've just had my w203 put on a generic obd11 reader.
these were the codes
P2024- check component B2/5b1 (intake air temp sensor) the signal voltage is too high
P0100- check charge air system. The air mass is too small
P1222- check component sensor in component B37(accelerator pedal sensor) The signal voltage is too high
the air mass one is probably where i disconnected it trying to see if thats what was causing my limp home mode. I did buy a new MAF including the housing.
The mil light doesn't come on when in limp mode which is now happening on a daily basis.
Any help on how to find and remedy the other 2 fault codes would be greatly appreciated.
