Fault Code Scanner........
Yes. I have one but I have lost the disc that goes with it.
Good tool.
I built my own using bits from Maplin.
I have a document describing the blink codes and pin descriptions, no disc required :)
This is public domain information, so if anyone wants it, then let me know.
Ohhh can I have it.
I had it on disc as it was easier to use.
Would this diagnose faults in the ABS system on a 190E 3.0 (M103)?
Doesn't look like ABS is available for code reading on W201 ?
My engine is a 300E though (or E300) and the ebay unit seems to suggest it (the ebay unit) has 16 connections and not 8, as shown in your diagram. Does that make any difference?
Sorry if I'm talking utter rubbish here, I have no understanding of this, I simply have some fault in the ABS system and really need some means by which I can diagnose what it is. And this looked like it might be a great idea.
As far as I can see ABS isn't covered on the 16 pin socket.
1 Ground
2 OBD Push-button for On Board Diagnostic (California only)
3 CIS-E
DM
Continuous Fuel injection system (CFI)
Diagnostic Module - LED (California only)
4 EDS Electronic diesel system
5 ASD
4MATIC
Automatic locking differential
Automatic-engaged four wheel drive
6 SRS / AB Supplemental Restraint System / Air Bag
7 A/C
RB
Air Conditioning (Model 124)
Roll Bar (Model 129)
8 DI
HFM-SFI
PEC
Distributor ignition
HFM Sequential multi-port Fuel Injection/Ignition system
Pressurized engine control
9 ADS
RB
Adaptive Damping System
Roll Bar (Model 124)
10 RST Roadster Soft Top (Model 129)
TN-signal (Gasoline)
11 ATA Anti Theft Alarm system
12 IRCL Infrared Remote Central Locking
13 ETC Electronic automatic Transmission Control
14 EA
CC / ISC
ESCM
Electronic Accelerator (Model 124)
Cruise Control / Idle Speed Control (Model 124)
Engine System Control Module (MAS), (Model 129)
15 Not used
16 Voltage, Ignition ON (Circuit 15) (Not equipped on all models.)
Ach, pity, it doesn't actually look as if it would be much use to me at all.
Thanks for the info DM - much appreciated
