Fault Code, Sprinter
ril
Sprinter 313
Hi All
I have a 2008 313 sprinter which has no traction in wet or slippery conditions, no dash lights or warning lights are on so I plugged in my Autel md 802 code reader and it gave me this code
FAULT CODE 5860
MIL ON & STORED & CURRENT
N30 / 4 (ESP CONTROL UNIT) - Version Coding String - IMPLAUSIBLE
I have cleared the code, changed brake switch and checked connections on the abs/control unit but it keeps coming back? Is the esp control unit mounted on the abs pump and if so and I replace both, will it need coding and do you think this will fix my problem?
Any Idea's Guy's?
Thanks :dk:
