SpikyMikey
- Nov 4, 2020
- Location
- The Sunny South Coast
- BMW F31 330i LCI M Sport Shadow Edition Black Series AMG Touring
The phone camera exaggerates the dust on the touchscreen.....honest!Very impressive!
Assumed it was the reflection from the starlight roof liner?The phone camera exaggerates the dust on the touchscreen.....honest!
Ah yes that's what it is.Assumed it was the reflection from the starlight roof liner?
That donāt impress me much.
I've got to say I'm impressed. OK, it is missing the 'essential' 2 cylinders, but 250 hp is more than enough for me these days. The ZF8 autobox is fantastically smooth in comfort mode and if you really want to wake up the neddies all it takes is to flick the selector across into Sport.That donāt impress me much.
I coulda told you about 44 mpg, and more power than you need, a long time ago.
Whatās impressive is how well it drives, and how it encourages you to press the loud pedal.
You should consider non-run-flats as well, depending on where you driveI've got to say I'm impressed. OK, it is missing the 'essential' 2 cylinders, but 250 hp is more than enough for me these days. The ZF8 autobox is fantastically smooth in comfort mode and if you really want to wake up the neddies all it takes is to flick the selector across into Sport.
I'm still cogitating (or as Mrs S says, "cogger-tating" ) over what to do wheel & tyre wise. Just prior to me owning it, it was fitted with a brand spanking new set of 19" staggered runflats (star marked and everything) which I'm sure made a considerable dent in the previous owners wallet.
Unfortunately they areFlintstoneBridgestone Potenza S001s, which are noisy and harsh on anything but a billiard table smooth surface.
Those that know suggest Goodyears are the way to go for runflats. 'Goflats' would be my choice, but with nowhere for a spare and a loathing and mistrust of a can of gloop, I'm not convinced that's the most practical of options.
An 18" square set up with 225/45 Goodyear runflats may be the way to go.
Still in evidence-gathering mode at the minute, so a decision may take a while! On my old E91 I ditched the runflats and carried a spacesaver spare in the boot when I had to go any distance. These days with the amount of company kit I lug around, this isn't an option. As to tyre brands, apart from steering clear of Bridgestone, I'm open minded.You should consider non-run-flats as well, depending on where you drive
I've had three E91 straight sixes but two F31 fours, so I've been around this issue several times. 18's will be better, and 17's even better, but there's that vanity thing that makes people buy wheels that aren't fit for purpose. How often do you get a flat, and where do you get them? (My last one was in 14 years / 200k miles ago - on an RFT, fortunately)
So what was my conclusion? I just stuck with what was on there, regardless. Even though I tour in Europe a couple of times a year, a long way from home.
The good news: you'll easily sell those 19's. The other good news: you'll easily find excellent 18's around, being sold by people who are "upgrading" to the worse, tram lining 19's. And you'll have a few hundred quid in your hands, net.
Well worth test driving a couple of alternatives before you make the change.
Just finally: you don't mention Pilot Sport 4's. They're well regarded for comfort. Have you dismissed them already?
Might be wrong, but the same engine as is in my Mini JCW.I've got to say I'm impressed. OK, it is missing the 'essential' 2 cylinders, but 250 hp is more than enough for me these days. The ZF8 autobox is fantastically smooth in comfort mode and if you really want to wake up the neddies all it takes is to flick the selector across into Sport.
Same basic B48, but a different iteration of it. Also found in Toyota Supra and Morgan Plus Four (!)Might be wrong, but the same engine as is in my Mini JCW.
It's interesting mooching about various car fora to note that Flintstones, either 'runflat' or 'goflat' flavours tend not to be the tyre of choice; they last well, but are generally not liked for the stiff sidewalls and noise levels.For what it is worth, I had 17"rims and run flats on the X3. Ditched those and bought myself a nice set of MICHELIN Primacy. The noise and ride upgrade was well worth the Ā£600 spent. I kept an unused gloop and inflator kit under the boot floor.
The little i3 does not have run run flats, but the ride is very brittle. I'm convinced enough to have just pulled the trigger on a new set of Michelin e Primacy given my own experience and reports of people who have swapped from Bridgestone to Michelin on an i3. The noise and comfort levels should be much better on a tyre developed some 10 years after the Bridgestone original....and did I mention anything about the added 6% range...
I know where youāre coming from Mikey. I ummmmāed and ahhhhhāed for a good 3 months about the same thing. The ride on our C Class estate on 19ā runflats was horrid. I was reluctant to goto standards because, like yours, no place for a spare.ā¦ā¦'Goflats' would be my choice, but with nowhere for a spare and a loathing and mistrust of a can of gloopā¦ā¦.
Sage wordsI know where youāre coming from Mikey. I ummmmāed and ahhhhhāed for a good 3 months about the same thing. The ride on our C Class estate on 19ā runflats was horrid. I was reluctant to goto standards because, like yours, no place for a spare.
I sought advice from that Silver Fox Bobby Dazz and I eventually went for it and fitted 4 19ā All Season tyres got myself a can of gunk + a Mikita 18v inflator.
The All Season tyres totally transformed the ride.
The first 2-3 months I was VERY aware I had no spare. But the feeling wore off so quickly. Iāve never given it a thought since. Plenty of long journeys to MancLand too. No bother.
When youāve got ya monies worth out of the runflats consider just going for standards. Iām sure youāll not regret it.
I had a good mentor!Sage words
I suspect the 'goflat' route will be the path I follow. The major decision will be whether to drop some cash on downsizing to a set of 18s and go up a profile. Certainly I should have no problem getting back a chunk of change by selling the 19s; as MikeInWimbers says, they seem to be popular on the second hand market.I know where youāre coming from Mikey. I ummmmāed and ahhhhhāed for a good 3 months about the same thing. The ride on our C Class estate on 19ā runflats was horrid. I was reluctant to goto standards because, like yours, no place for a spare.
Heās changed since he started doing the coffee adverts.I suspect the 'goflat' route will be the path I follow. The major decision will be whether to drop some cash on downsizing to a set of 18s and go up a profile. Certainly I should have no problem getting back a chunk of change by selling the 19s; as MikeInWimbers says, they seem to be popular on the second hand market.
How did we ever manage without the benefit of the teachings of The Oracle, The Font Of All Knowledge otherwise know as Mr Bobby Dazzler?
It's the new-found fame and fortune - not to mention all that caffeine.Heās changed since he started doing the coffee adverts.
Yep. Constantly Off his t!ts!- not to mention all that caffeine.
