scruffy
anyone know how to format a new hard drive and prepare it to accept xp operating system, thanks
scruffy said:anyone know how to format a new hard drive and prepare it to accept xp operating system, thanks
This can be done with the XP setup process though, in fact it's better done by that than by the windows 98 fdisk/format combo!Ian B Walker said:If the drive is as you say new, have you FDISK'd the drive yet. The drive needs to be prepared for data. Just a question
Shude said:Win98 boot disk should be sufficient, if the cd-rom driver etc is on the floppy then you can run the winxp setup from the folder on the cd. i
IanBWalker said:If the drive is as you say new, have you FDISK'd the drive yet. The drive needs to be prepared for data. Just a question
Shude said:This can be done with the XP setup process though, in fact it's better done by that than by the windows 98 fdisk/format combo!
Not got another cd-rom drive knocking about?scruffy said:drivers not on it and don't have them on cd either
Did you check master/slave settings on the devices?scruffy said:won't fdisk, error message reads 'no fixed disc present'
Shude said:If you have a spare PC then I'd just configure it on that machine instead - fdisk/format then copy the contents of the XP disc onto the HDD in a setup folder, put the 98 system files onto it so it boots, don't forget fdisk /mbr (not always done by default) then put the HDD into the other PC again, let it boot into dos then swap to the setup folder and you're away. Faster than installing from the CD in most cases.
Where in lancashire are you?scruffy said:good idea, like it, I'll give it a whirl
much appreciated
Shude said:Where in lancashire are you?
Ahh, bit far away for me to just pop by then - I live in Rochdalescruffy said:Poulton Le Fylde, just outside Blackpool
Shude said:Ahh, bit far away for me to just pop by then - I live in Rochdale
