Front brake disc diameter
johncherokee
Wensley
CLC200k
How can I find out what size my brake discs are on my CLC200, year 2008? I can’t kneel down to get the wheel off to measure it, and I want to buy a pair of new discs.
You dont need to remove the wheel , through the wheel spokes put a straight edge on the top of the disc and one on the bottom of the disc and measure the distance between them.
K
K
Needs less hands if you measure from the outside edge to the hub centre and double it!
Needs no hands if you use small magnets to hold the straight edges onto the disc.
K
Let the person fitting them, measure. No hands needed , nor magnets and straight edges 👍👍
My guess would be 288 mm
Unfortunately I need to buy them to have them fitted, so I will have to find another way, but my guess was also around 288 on the front. Large is better!
Check on any website using your reg number. 👍 most companies cross reference parts against your reg and send the correct parts.
Use the vehicle VIN and ask Mercedes Newcastle (or Edinburgh) to quote.
But sometimes they get it wrong.
Far better to use an EPC and your VIN number to get the original MB part number. Then go to MB to buy them.
Or, if you wish to buy elsewhere, search for the MB part number at, for example, AutoDoc, and they will come up with various aftermarket alternatives. Then look for known good makes such as ATE, Brembo, Zimmermann, etc.
Here's an EPC:
Good hunting.
RayH
Here's an EPC:
Good hunting.
RayH
Autodoc don't get it wrong do they . Pmsl. 🤣🤣
A drive to a local ecp store is better than shipping back to Germany , Shirley?
There were two different size options when I replaced my front discs with not much between them. It's not easy to measure a diameter accurately when there is a hub in the way so another option is to measure the circumference and divide by 3.142. I was confident enough of the measurement to order from Autodoc and they were the correct size.
I should coco. But I always use the MB number and cross-refer. Whoever the aftermarket supplier.
I've only used ECP once around 2005 and got Bremi ignition distributor cap and arm. Utter rubbish and binned in 6 months. So it's best to select an appropriate aftermarket brand, of which there seem to be less and less for qood quality, sadly.
R
R
I always shop for OEM brands . Brands that supply mb but don't charge mb prices. 👍👍
Yes, but quality may not be what is was. I had a new Bosch distributor cap fitted by some cowboys near Toulouse, and it was cracking after 9 months. They didn't need to touch the cap as I'd explained the problem. Bosch cap binned, replaced with cleaned up MB originals. All well.
And others are questioning the quality of Lemfoerder, Beru and other OEMs. I binned a new set of Beru plug leads as they just refused to snap cleanly down on to the plugs - 15 year old Berus no such problem. Similar with new NGKs that I also binned. I bit the bullet and had MB make up a set of leads and they "felt" totally different - snap on to the plugs, happy.
Depressing isn't it?
Oh, and I have seen people question the quality of recent MB-supplied parts. Even more depressing.
RayH
RayH
Not got much luck have you.
