350_Coupe
Hopefully this is the right/ok section for this.
Was having some other work done recently, Electronic Thermostat failure, on my 55 plate C350 Coupe (203) and whilst they were investigating that, they found this stored message.
SAM-F Signal Acquisition and actuation module front
CODE: B1003
STATUS: Stored
TEXT:
The dealership was less than concerned, explained it's a pump used at idle to assist the main water pump in shifting the water through the heater matrix during idle, and was not uncommon to fail, and as things go, it's not exactly urgent, if even worth doing !
Additional info gained from them, bearing in mind it was not there for this fault,
1. The pump is fitted on my car
2. it apparently is working, if you feed it 12v
3. it does not respond via stars, or through the main wiring loom, hence the odd error message
they seem to think, it's a wiring issue, or perhaps a fuse.
Can anyone shed any light on this ? i am at a bit of a loss, because i really don't know much about this, even to the point of where it is, and where it's powered form, obviously it's controlled from the front SAM, or if there's a fuse in the line somewhere, and even if i find a wiring/fuse issue, how will i know if it's fixed the issue, given that i had no idea the problem even existed!
CODE: B1003
STATUS: Stored
TEXT:
Component M13 (Heating water circulation pump) or the line to the component has a short circuit to ground or open circuit. Component M13 (Heating water circulation pump) is not installed. Ignore fault code if it nevertheless occurs.
