Front window washers C270CDI
davynick
SHETLAND
C270CDI AUTO AVANTGARDE
After spending hours fixing rear window washer my front window washers have packed up , no motor noise but rear still works ?
Are front and rear governed by same motor ?
Is there a relay ? fuse card says "electronic" ?:wallbash:
From memory the rear is on a different pump.
When my front pump went I can remember looking it up on the epc and I'm sure for the estates it had a seperate.
This just remembered me my front headlight washers aren't working! :wallbash:
window washer failure
Looks like the colour of the tubing suggests the headlight washers are on same circuit as rear washers ?
Looks like the windscreen motor has expired or almost, has been a little weak for a while
Anyone know the part number of a new one ?
Luckily due to the summer that never was my windscreen is always wet!
Replaced the front washer motor but still a dribble, daft thing is just before i changed motor, washers sparked into life full force!! thought I would check and change anyway and its now back to a dribble!! will have to check voltage.Tubes seen clear could my system have a check/non return valve ?
If it was sticking that would explain a lot !!:mad:
Front washers have a non return valve built into the washers.
Try disconnecting the pipe to washers and see what pressure you get
